Reset a QuickPanel by Total Control
Earthscape
Sep 2011
PNW
86
This belongs to a client who apparently had to order it from Nintendo. It was used, and came with an IP on it already. I'm looking to add it to their control network, as they have many of these installed currently, but I need to change the IP. I get nothing at the Splash screen, and don't know where else to look. Anyone know how to either reset this or give it a new IP ?
It is a CQPICTDE0000-A, Model # 2990045-01.
Thanks guys.
Nevermind, I found it. FYI, if you ever have to deal with these devices, touch all 4 corners of the screen for a few seconds and it'll kick into configuration mode. The setup is all done from that screen.
Hi to everyone! I have a trouble to Go Online with my QuickPanel IC755CS (I can ping it - connection via Ethernet is fine) the reason is dialog...
5,023
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
308
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
74
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
109
