Resizing alarm banner panelview plus 600?
Shiro485
Apr 2013
North Haven CT
103
The banner is completely unreadable. Is there a way to adjust the size that the alarm banner will display on FT ME 7.0 for application?
Thanks ☯
When you create a new application in FTView 7.0, the software assumes a screen resolution of 640x480, which matches the popular PanelView Plus 700 and 1000 terminals. I thought I remembered that earlier versions required you to choose the resolution before creation, but I checked version 6.10 and it behaves the same.
Anyhow, that means that you have to re-size the Project, which by default scales all the screens and screen objects and fonts. The default Arial 10 font in the Alarm Banner object on the [ALARM] display becomes Arial 5, which I agree is (nearly) unreadable.
You should just be able to go into the Alarm Banner object properties and change the font settings back to Arial 10. The number of characters visible will decrease, so your alarm messages will need to be short. But isn't brevity the soul of wit ?
Hello! I have a question regarding the HMI in InTouch, almost a month ago I made an HMI and I have not used it again, now I need to make changes...
2,044
Hi there, Been working adding new pages and features to an existing SCADA and have encountered a strange error when it comes to the sizing of...
1,569
Hello guys i have a question about resizing of global objects in FactoryTalkView Studio (8.2). I want to resize objects linked to global...
21
9,196
I have an ifix 5.5 database linked to IGS 7.514 coming from rslogix 5500 plc. I'm having an issue where the string value inside the ifix database...
1,962
OK. I'm going nuts. I have an existing PC HMI FT View Studio SE 6.10 project that was set up on an older 3 x 4 style monitor with the displays...
3,952
