Resolver splicing
The resolver decoders I have worked with only look at the Sin and Cos returns relative to each other. So technically that should work. However you will need to be VERY careful of signal degradation due to input loading, noise and comon mode voltage differences.
Keith
You can get a signal divider for encoders (1 in 2 out). Not sure of make it was a while ago. But I do know they exist.
He said RESOLVER. I don't know of any PLC that can directly read a resolver signal [Sin+,Sin-,Cos+,Cos-]. Maybe a special expansion unit is required?
:unsure:
Hello, We have been floating around the idea of making a test bench / training station in our facility. Our two biggest "customers" for servo...
1,096
Is there an easy way to put back a resolver that was accidentally removed from a servo motor? Thanks for your feedback
1,523
Hi, I have some Baldor (Baldor is now ABB) servo motors that have revolvers for position output. But to my surprise the Baldor MicroFlex...
3,793
I have an older SLC500 that has a PLS card in its rack. I want to remove the SLC and add a L23E-QBFC1. Can a resolver be wired up to the High...
1,691
Hi. I have a 1326AB servo motor and its resolver is out of tune. How is the procedure of mechanical manual phasing in Allen Bradley? Is that V+...
2,123
