Resolver vs Encoder
A resolver is a transducer that uses a stator winding and rotor winding to produce waveforms for shaft angle measurements for positioning the generic term for these types of transducers is synchro. An encoder is an electrical mechanical device to measure motion or position. Usually in applications other than on the stator or rotor windings
Take a look at this web page for a very brief description of resolvers and synchros. You will see that, although they use the same concept, there is a difference between them.
Resolvers used to be the mainstay of brushless AC motor drives back when the drives were analog. Resolvers are absolute position devices, a good characteristic for motor commutation. The decoded resolver information also lent itself very well to commutation. And, best of all, a resolvers is just about bullet-proof. It has no on-board electronic components and no fragile mechanical components like encoders do.
However, resolvers do have bandwidth issues that may cause issues in some applications.
With the advent of digital drives the resolver isn't as popular anymore. Digital drives can easily handle commutation based on the variable position offsets that an incremental encoder system may create. And encoders don't suffer from the bandwidth limitations of the resolver quite as severely. So many of the drives today just go the encoder route.
A good rule of thumb is if you need absolute position within a shaft revolution and you need the sensor to be tough, consider resolvers.
Keith
Another thought, here in the steel industry where electrical equipment are exposed to a tremendous amount of heat etc, I find resolvers outlast encoders by a long shot, and I personally like programming with resolvers way better than encoders, esp dealing with power lost etc.
Hi All I need to test/program a GEM80 FIFAC 9274 resolver/synchro encoder card. Does anybody have any information about this card or know how to...
1,071
Hi all i need to know how can i determine the encoder or the resolver when i order it ? by other words ( according to what can i choose the...
1,478
HI every body I have in my work a more type of machines which uses (RESOLVER) and the other one uses (ENCODER), but i know the concept of...
19,832
Had a unique question today and can not get a bare bones answer. We have a resolver (several of the units) and when they go out, you start...
1,994
Hello, We have been floating around the idea of making a test bench / training station in our facility. Our two biggest "customers" for servo...
1,094
