Retentive Internal Bit
dbh6
Jan 2013
Central, NJ
552
In Logix 5000 software, how do you make an output (OTE)bit retentive such that when power is lost and resumed, the status of that bit will be in the state it was in prior to the power loss. Thanks, i know in structured text when you use the assignment operator ":=" is retentive and "[:=]" is non retentive, unless by default your OTE bits are retentive, then if thats the case how do you assign a non retentive OTE?? Thanks.
OTL to latch. OTU to unlatch. It will retain its state through a power loss.
Technically, in an AB PLC all bits are retentive. On a power up or go to run mode event a prescan resets all normal OTE bits, TONs, etc. If you look at any instruction under the online help there is a section on what happens during the prescan.
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,932
Having trouble with a Siemens S7 226 counter being retentive. I have specified in the System block C ranges offset 0, 6 elements. However, at...
284
Been a long time since I've posted, but here we go. Started a new role in august and progressively learning about Codesys programming in...
1,172
GE 90-30 using ME 6.0 - Newbie question... Let's say on rung 10 I set a coil (S) with a one-shot. Input to coil drops out, but coil stays...
30
11,147
Need some insight into why this happened. After finally getting a VM to connect to a CPU 216 2 siemens processor, uploaded the program. made a...
2,569
