Retrieving program from CM1746? (used w/ AB SLC 5/03)
Erica_S
Aug 2011
Louisville, KY
Hello.
I am using an Allen-Bradley SLC 5/03 CPU (1747-L532) with a CM1746 RFID
Interface Module in the slot. They are mounted to an RFID reader with a tag and a few buttons (it's a testing station).
The main issue I am having is that I need to retrieve a previous custom C program from the CM1746 and the manufacturer no longer exists. I am currently trying to communicate with it via Windows HyperTerminal and it seems to do nothing.
Basically what I want to know is:
  • Is there any way I can upload the program? If so, how?
    Can I communicate with Windows HyperTerminal? If so, what I am doing wrong? If not, what other programs could I use?
I have attached some useful documents such as the datasheet, manual, and FAQ doc. Thanks.
Bump. Really need help with this.
I have managed to get HyperTerminal to react to the card and I have attached a screenshot of what I get.
Now I just need to figure out a command sequence of some sort to possibly make a menu appear. I will keep digging, but some help would be nice.
Thanks in advance.
Might Help
I found this document online with a search. I couldn't link to web site so I uploaded the document. Hope this will point you in right direction.
Erica call George or Sam at CED they might be able to help.
I am in Corydon IN if you need local help.
Hi all. I'm in a jam and need some advice.. I'm trying to retrieve the program from an S7-1200 PLC. We don't have a copy of the program or even...
1,800
Hi, I am a student doing a TR on replacing an old plc. I need help getting the program out of and old Telemecanique tsx 7 47 plc. What software...
3,511
Good afternoon. I am looking for a way of getting the program name and compile date/time from all of the PLC's in our plant so I can...
3,436
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
151
I have a strain gauge attached to a load cell. The strain gauge is wired into an analog channel on a ControlLogix 1769 controller at +/-10V. How...
2,435
