Retrieving a program off of and old telemecanique tsx 7 plc
Andrew281180
Jan 2013
Ontario
Hi, I am a student doing a TR on replacing an old plc. I need help getting the program out of and old Telemecanique tsx 7 47 plc. What software will I need?
Thank you,
Andy
What model is the CPU?
Some of these units are PL7/2
You will also need a special cable with a current loop converter.
I will post reference numbers later after I check my cable.
I Need to do the same with 2 TSX 17's on some dock locks.
Not a big deal though should be able to change to
Micrologix 1k if these units eventually give up.
Oops the pic is upsidedown.
Hi all. I'm in a jam and need some advice.. I'm trying to retrieve the program from an S7-1200 PLC. We don't have a copy of the program or even...
1,793
Hello. I am using an Allen-Bradley SLC 5/03 CPU (1747-L532) with a CM1746 RFID Interface Module in the slot. They are mounted to an RFID reader...
3,979
Good afternoon. I am looking for a way of getting the program name and compile date/time from all of the PLC's in our plant so I can...
3,433
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
I have a strain gauge attached to a load cell. The strain gauge is wired into an analog channel on a ControlLogix 1769 controller at +/-10V. How...
2,429
