ROC 800 liquid meter problem...
timothy585
Supporting Member
Apr 2021
Cajun Country
47
A new LACT skid was delivered seemingly identical to the other 20 before. We have a config file that we have been able to download without issues and get the skid tested and in service without issue.
I have a ROC that seems to be working fine with the current config except for the liquid meter I/O. I can see the raw pulse count on the APM module update just fine. When I go to the liquid meter "INPUTS" tab the I/O definition TLPs are the same as the other units, but on this running config, the "Values" next to the TLP points are not updating at all. Everything else in the config is working fine...all my action blocks, FST's, etc. It's just my calculated flow rate and it's associated parameters (press, temp, BS&W, etc) that are not updating their TLP registers.
Any suggestions or tips are appreciated.
I'm on a job with about 75 ROC 800 LACT packages installed and running. We have a single template program that works good and is basically just...
978
Anyone happen to be familiar with ROC 800 flow computer hardware? I'm new to the ROCLINK 800 programming software and I have a quick question...
818
Hello, I am needing help with the configuration of a ROC 800 RTU, I have not been able to configure the softpoints with measurement instruments...
819
Hi guys, I'm trying to configure a rate of change alarm on a setpoint tag so that when the operator types a number by error (exemple: 30 instead...
174
Today I was making an online edit to a 5/40 Series E Rev K.2 with about 14% free memory. I was removing one branch in a large rung. Accept...
3,176
