Rockwell 1756 - Cabling
dalporto
Jun 2021
Montreal, QC
258
Hi all.
I'm having a hard time figuring out which cable goes with which module from Rockwell documentation, and my local Rockwell representative is out in the US for training.
This it what I got so far:
1756-IB16i: 1492-CABLE050TBCH
1756-IB32: 1492-CABLE050TBCH
1756-OB32: ???
1756-IF4XOF2F: ???
1756-IF8i: ???
1756-IR12: ???
I think that 1756-TBCH is the 32 pins connector which is already mounted on the 1492-CABLE.
Can I plug that 1492-CABLE050TBCH on every module, or do I need to buy separate 1756-TBCH and do my own wiring?
Thanks.
It's, it's more like it!
Rockwell should have something like that.
Thank you very much!
Hi Guys, Here I have started to work on some difficult task, I hope I will get solution here. we have ABB CI-840 Master IO Module needs to be...
602
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
578
I have a spec that requires cable redundancy whether or not it makes sense. Also, I have to have redundant Processor Chassis where only one is...
3,209
Hi Guys.... I am facing one issue. PLC Controller i.e. 1756-L74 is now showing the error as T03:C16 IO connection Failure.... What can be reason...
1,615
I am using a 1756-L72S processor, in an already running line. I have a 1734-AENT module that is giving a fault code "Code 16#0010 - Mode or state...
1,388
