Rockwell Add On Profile
JeffKiper
Jun 2006
Indiana
2,464
Has anyone ever build a Add On Profile? I have a few customers that build EIP devices. I hate adding a generic Ethernet Module for each device from them. So I was thinking if there was a way I could build a AOP it would make things easy to implement in RS5000. I am writing the baseline Ethernet IP user manual for implementation into the AB world.
Any advice
RSLogix 5000 v20 has a new feature of "EDS-based Add-On-Profiles".
Classic AOPs are little applets that integrate with RSLogix 5000. They have to be carefully integrated with RSLogix and require a lot of testing and revision support.
EDS-based AOPs will allow you to create an I/O object with a structured UDT that's automatically created when you add the device to the I/O tree. The structure of the UDT will be determined by the [ASSEMBLY] section of the EDS file.
I think that they're supposed to also allow a Parameter object tab, similar to the Parameter Editor in RSNetworx.
But I haven't seen one work, yet. Every third-party EDS I've tried to import fails in some way, usually by creating incorrectly sized or un-named data blocks.
I was told that RA will be writing an 'EDS-based AOP Implementor's Guide" but I haven't seen a draft or other information about it.
See if you can get some information on that from the Technology Sharing / "EnABled" group at Rockwell, or send your distributor specialist to RSTechEd with a mission to find out about it.
Ken do you get the RTA newsletter? John Rinaldi did a write up on the V20. He didn't have have a lot positive to say about the hype. At least that was my take after reading the letter.
I decided to just write this manual from someone with a basic understanding of adding EIP I/O to a controller.
Pretty sure I should know the answer to this, but stumped.... I am working on an oldish Logix5000 (ControlLogix) project, version 16. The...
2,076
Hello everyone I would like to add the Rockwell Software OPC Automation Namespace into my VB Express 2010 project, but i could find it.:bawling...
6,662
Does anyone know where to find examples of add-ins for plc5/clx ?
2,677
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
50
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
122
