Rockwell Automation Activation Error (EVMOVE)
JulienV
Dec 2007
Montreal, Quebec
52
Hi! I have a problem with my Rockwell software activation from a Toolkit master disk (keys for all their automation softwares). I used DriveImage to duplicate my 40gig HD to a 100gig HD and everything worked fine except that after a few days, the activations stopped working. I thought "no problem" as I have a backup of my master disk with valid keys on it, but when I try to move them I get the error message "Activation File Corrupt - Invalid Serial Number". No mather what I do I get this message...
I've seen old posts (2003) on this forum about a similar problem and to look for a EVRSI.SYS file but such file does not exist on the HD (yes I checked hidden files). Anyone experienced that problem?? Please help!
Julien
Julien
Have you checked for system files?
Thanks a million buddy! That was the key to my sucess! System files were still hidden and when I fixed that, 386SWAP.PAR and EVRSI.SYS finally appeared. I deleted the files and tada! Problem solved! Thanks again for the hint!!!
Julien
This is something that you probably don't want to leave posted. I'd recommend editing those file names out of your reply out of respect for Rockwell and the agreement here. I'm not sure that you're getting the significance of the info.
I'll explain the details if a moderator asks.
Nothing special about those files (see AB knowledge below)
While trying to get a new Activation for Rockwell engineering softwares, the following error keeps popping up. What could be the issue? A system...
2,785
Good Evening , I am new to the Rockwell Automation Toolbox. Apparently you need to activate this each year. I have a serial number to...
2,538
Hi I have set up a new laptop with a high speed SSD Win 7 SP1 64bit host with a Win XP SP3 virtual operating system through VMware V10. The...
11,593
I moved my old Master License for Rockwell Automation products to a new PC and successfully installed the Control Logix 5000 license. But i have...
4,610
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
99
