rockwell borrow activation between 2 laptops
Option 1:
Rehost the license. You can do this 3 times in a year.
Option 2:
Set up a 3rd PC, say, a desktop in the office as the license server and have either laptop borrow from the server.
Option 3:
Setup one of the PC as the server and have the other PC borrow license as needed.
jkerekes's "use a dongle" must be option 0 then....
actually it is the easiest way, I use my dongle to activate software on my home desktop, two laptops, and a couple of clients' machines when working on-site.
No worries about not being able to connect to an "activation server" when needed.
Plus it is a 2GB memory stick, so the .LIC license files can be transported with the activations.
The only drawbacks are....
1. You must remember to take it with you wherever you go... (not failed yet).
2. You have no "plan B" if it stops working.
3. It sticks out the side of my laptops, not the rear, so is a bit exposed to being knocked.
Hi can anyone tell me how I can borrow an rockwell activation between 2 laptops thanks stu
What type of activation? Older EVRSI or Factory Talk?
If Factory Talk:
- Is there the activation client or server installed in each computer?
- Is the activation tied to the hard disk serial# or to the MAC address?
Can you see over the network the computer with the activation? If so you can point the computer that you need the activation on to the computer with the activations. Just tell the Activation Manager where to look.
Hello PLCS.net! I have a server running with FactoryTalk activation manager on it. I activated a RSL5000 license on it, and can borrow/return...
1,923
Hi Guys, Anybody have idea how to borrow Rockwell activations from one virtual machine to another. Both machines have no physical/network...
3,631
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
174
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
131
