Rockwell Cables
Ngaraju
Oct 2012
Hyderabad
Hi Thanks All,
I am new to Rockwell Automation Service.
So What are the different communication cables for the Rockwell Products
:sleep:
Powerflex drives (at least the ones I am familiar with) use a protocol called "DSI". It stands for Drive Serial Interface and is an Allen Bradley protocol. Of course a lot of this varies based on what PLC you are using, and I'm delving into the subject myself, but you need to remember a few things about cables:
1. A cable is more than just "a connection". Even if a cable has the appropriate connectors the pins may or may not be correct, and this goes for voltages too. Some PLCs have an RJ-45 port (such as my SLC 5/03), but one of the wires runs at 24V, which will fry a standard nic used in computer ethernet applications.
2. You need to familiarize yourself with RSLogix and the different cable types for connecting, if you have specific questions on connecting to a PLC I would be glad to answer them, as this is often half of the battle when you are new. I spent a week learning to connect to different PLCs and trying different cables (like serial to usb). There are a TON of modules out there, but each one has a specific purpose and protocol.
3. For any kind of PLC network utilizing older protocols/hardware you will need some kind of device to keep track of the other devices on the network. This device is referred to as a "Master."
4. I reiterate that there are a TON of different protocols and ways to connect. You can, for instance, use analog to connect to a Powerflex drive and control it's speed.
Our local AB "Drives Guy" came in the other day and had a cable that he said would connect USB to virtually any AB AC Drive or Servo Drive. It had 5 or 6 different ends on the one end of it, and a USB on the other. He told me the name of the cable, but I have forgotten it since...sorry, might check your local AB Distributor and ask about it...seemed like it'd be pretty handy to have around...I need to check on it myself in fact!! :)
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
73
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
34
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
131
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
198
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
139
