edwardeduful
Hello Friends,
please i am having a challenge with stratix 8000-1783 MS10T and Rslogix 5000.
The issue is All the network switches(stratix) have got password and i do not have the password to online to see the running configuration.
So i took another switch with the same firmware version(4.002),programmed it by opening the ports as well as the fiber optic ports, and also gave it the same IP address as in Rslogix 5000 I/O config from the PLC.I replaced the old switch with my new switch and there was no communication, i removed the IP address and still no communication.i went online to the PLC with old switch, right clicked the properties, checked on module information and its revision 4.002.
when i click on the general tab i see 4.001.as the version.
Please your advice is needed, Do i have to do more configuration on the switch or Rslogix 5000.
Please your help will be appreciated.
