Rockwell controlnet Connection?
wilsonzhu
Jan 2008
vancouver
278
Hi, I have a big project which has 6 17-slots Racks connected by Controlnet. How much the maxium scheduled Controlnet connection? If I use comm formt:Rack Optimization instead of input/output Data for DI/DO Cards, Will it save Connections? Thanks,
Yes, using Rack Optimisation will reduce the number of connections utilised.
Example : A 17-slot chassis full of Digital* I/O modules will require 16 connections. Using Rack-Optimisation reduces that to 1 connection.
* Analog I/O modules cannot be added to the Rack Optimisation method.
Disadvantages : None except that all digital I/O in the chassis has to run at the same RPI rate. If you do need an I/O module to run at a different rate, it can be added to the configuration so as not to use Rack Optimisation.
What's the maximum connections for Scheduled controlnet?
How to change Comm format, it's grey color, I can't change, Does it must delete and then add?
Yes, you must delete and put back in Rack-Optimised format.
The reason is that this changes the Module-Defined tags that are created, and any existing I/O references are aliased into the rack-optimised tags. This subject usually takes me an up to an hour to get across to most people.
Connection usage is limited by :-
a) The processor - 250 maximum
b) The comms module - the CN2 have twice the nunber of connections than the CNB, the specs will tell you how many each module will support.
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
21
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
119
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
182
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
131
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
131
