Hi all,
I'm using this faceplate to look into my DLR network, I have correctly set up the faceplate code within the PLC and as a test has a network with three cards on two different racks.
The faceplate gives the correct information of the supervisor node but it also contains errors and does not correctly display the IP addresses of the cards on the network. It also displays an error saying there is no Supervisor node above where it states the Supervisor information (which is correct).
Under the "Ring Participants" tab it looks as though the last digit on all the IP addresses is being cut off. It is also not detecting the MAC addresses for these IP's.
Anyone have these kind of issues?
