Rockwell DLR vs. EtherNet/IP question
daff
Oct 2012
Chicago
Hello,
I have a customer with a Rockwell DLR network. I wanted to know if a regular EtherNet/IP slave/adapter device can be added to this kind of network?
I haven't checked into this as closely as I should have yet but I think you can use DLR-equipped devices to implement a linear topology architecture. In that case you should be able to put a single-port device on the end. However, if it is a true DLR implementation then the device Ken referred to is required.
Keith
Does anyone know of an IP67 field-mountable Ethernet switch that supports the Rockwell "Device Level Ring" protocol, but isn't a Rockwell...
1,334
Hi all, I'm using this faceplate to look into my DLR network, I have correctly set up the faceplate code within the PLC and as a test has a...
3,213
Customer is adding an extension rack to an existing A22. They wired and powered it up, I configured the new cards in the PLC starting from slot 23...
49
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
82
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
42
