Rockwell DLR vs. EtherNet/IP question
daff
Oct 2012
Chicago
Hello,
I have a customer with a Rockwell DLR network. I wanted to know if a regular EtherNet/IP slave/adapter device can be added to this kind of network?
I haven't checked into this as closely as I should have yet but I think you can use DLR-equipped devices to implement a linear topology architecture. In that case you should be able to put a single-port device on the end. However, if it is a true DLR implementation then the device Ken referred to is required.
Keith
Does anyone know of an IP67 field-mountable Ethernet switch that supports the Rockwell "Device Level Ring" protocol, but isn't a Rockwell...
1,335
Hi all, I'm using this faceplate to look into my DLR network, I have correctly set up the faceplate code within the PLC and as a test has a...
3,217
Hello all, I am an Industrial Electrician, and deal with a little bit of everything including PLC troubleshooting and programming. When I started...
114
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
85
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
153
