Rockwell Factory Talk View tag purge
kirk
Jul 2003
Houston
71
In Rockwell Software, Factory Talk View ME, is there a way to purge the tags that are not in use anywhere within the screens of program?
As far as that goes, I have Micrologix 1400 program that has tons of tags that are not in use in the current program, can you purge RSLogix 500 of tags that don't occur anywhere in any logic?
The program is so cluttered it drives me nuts.
He's after a way to do it in FactoryTalk View ME, not RSLogix :)
I've never found a way to do it, and I'd be interested to find out too...the only way I can think of - which is ugly, and pretty much brute force is to export all your tags, then delete the whole lot. Then test your application, visit all the screens, press all the buttons and view the diagnostics log. For every tag that IS used, you'll get an error message. Mark them down as used in your excel file, reimport those ones and repeat until you have no more errors.
Like I said. Ugly, brute force ;) hopefully someone else has a better idea!
We have a FactoryTalk HMI running on an industrial PC. Which software do you need to edit and add screens to this ? I'm confused with Factory Talk...
3,818
Hi I have just installed the Rockwell Faceplate for the 1769-L3x Controllers. Its working well however the memory is not displaying properly. I...
3,033
Hello, I'm developing and appliacation, where I going to use an Advantach HMI (Industrial Computer) and a Remote Computer (Desktop) running at...
6,012
Has anyone here successfully used the View SE software under windows 7? I have gotten Linx Pro, Logix 5 and Logix 500 to work, but I cant get the...
13,187
Hello! I am using an AB Versa View 1200p with Factory talk View Machine Edition, version 5.0. I am having trouble printing out the alarm...
4,168
