Rockwell Kinetix Servo MAPC instruction . What is a 85 Fault ?
Aug 2016
Virginia
343
Good Morning ,
I'm having a problem with a Kinetix Servo MAPC instruction. I keep getting a #85 Fault. Could you give me some understanding of what this Fault is ?
Thanks and have a great day .
https://literature.rockwellautomation.com/idc/groups/literature/documents/rm/motion-rm002_-en-p.pdf
page 558, under the heading "Motion Error Codes, faults, and attributes", subheading "Motion Error Codes (.ERR)", you get a good description of the 85 fault.
Instruction not allowed when redefine position is in process.
Performing MAH while MRP is in process results in this instruction error.
Homing, redefine position in progress
An Active Redefine Position instruction is in process.
You would get this error if any of the motion planner instructions are executed while MRP is in progress. Motion Instructions included are: MAM, MAJ, MCLM , MCCM, MATC, MAPC , MDAC, MDCC, and MCPM
Good Morning , I'm having a problem with a Kinetix Servo MAPC instruction. I keep getting a #85 Fault. Could you give me some...
1,130
I have in a plant, a machine that cuts parts in pre- defined sizes , but need to phase this cut parts . The system is using servo Rockwell Kintix...
1,856
Hello, First thank for all the help i've gotten through this forum over the years reading others threads. I'm having an issue with Kinetix 5700...
5,926
Why the Position Loop Bandwidth, in Rockwell axis of Kinetix 5700 Servo Drive, is in Hertz ? Same for the Position Integrator Bandwidth . What is...
2,711
Hello Everyone hardware: 1769-L36ERMS Compact GuardLogic 5370 Safety Controller, revision 30.014 drive: 2097-V32PRO-LM Kinetix 350, 2A, 240V...
1,869
