Rockwell License Problem...
bluenoser337
Apr 2003
Nova Scotia
391
Since installing Linx Enterprise (think that's what did it) there are always several processes that keep running after I finish with RS software. These running processes prevent transferring RS licenses to the floppy "master disk" because the "license is in use". If I stop these 4 proceesses via task manager, I can move my license to the floppy. Is there a way to have these processes (RnaDiagnosticsSrv, etc) stop when not using RS software?
Bottom right hand corner. Look for RsLinx icon. Right click, Shutdown RsLinx Classic.
I would only do it when moving activations, leave it on the rest of the time
I tag all the Rockwell Services to start in Manual using,
Control Panel -> Administrative Tools-> Component Services -> Services.
Scroll down on the list of services and set all the Rockwell sevices to start up in manual mode, then reboot your PC
Ian
TW...tried that but some of that FactoryTalk stuff that loads with Enterprise (i think) won't go away. Think I'll check out the option to start the services manually. Thanks all!!
I didn't think that RsLinx Enterprise messed with the activation files but it has been a while since I used RsLinx Enterprise
I just got a new Windows 10 laptop to use at one of our facilities. I need to move my RS5000 software to this new computer from my Windows 7. Will...
2,082
Our IT Manager buys our single Rockwell seat under his Rockwell.com log in. Right now I can access our software with a serial number to download...
2,590
Is there something like Help About that will tell you that each Rockwell application is licensed? The Activation Manager just shows every...
2,764
Hello PLCS.net! I have a server running with FactoryTalk activation manager on it. I activated a RSL5000 license on it, and can borrow/return...
1,930
Hi my company hosts our licenses on a server located in the USA where I am based. When in the office on the domain or travelling in the USA (VPN)...
3,642
