Rockwell Logix Designer tag referencing?
mbruins
Jan 2017
NC
Confused here.
I'm working with a program supplied by a machine OEM, trying to add some additional devices and equipment to it. Came across something I have not seen in my limited experience with LD.
following some of their ladder logic, I cross referenced a tag as shown in the attached pic. Note there is an XIC instruction that is in the list that has a different tag reference. I have never come across that and I am not sure how that is possible. I have looked at the properties of each tag and neither are alias' of the other, nor is there anything else in the properties that links the two other than the slight difference in the tag names.
How can this be?
Confused here.
How can this be?
Don't know about this a 100%, but are they JSR/SBR Parameters?
that was it. Safety mapping. This is my first go with a controller that has safety in it, and I didnt realize safety mapping was a thing.
Thanks for the help!
hello all, If hundred versions of rslogix were not enough with rslogix. Rockwell even has logix designer . What is the difference. Does version...
17
7,193
Hi... I have what is so-called "Limit Values" placed in the Safety PLC. These values ​​were written in REAL safety tags format. It turns out...
431
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
931
Good Evening, I'm loading a recipe into a Rockwell ControlLogix or CompactLogix CPU via Excel, this is all working fine. Is there anyway I can...
2,052
Hi All Predictably, I have a problem making Intouch talk to compactlogix 5380 plc !!! In Intouch I've declared : Access name = Tank_Farm Node...
704
