Rockwell Panelview + Data Logging ?
EICS_2
Mar 2015
Melbourne
49
i have a panelview plus HMI.
i want to data log when certain digital events occur but not have this in the alarm list (or alarm history) it is for maintenance purposes of when a certain process has completed only.
the log needs to contain date & time.
Any idea's?
Use their Datastore ActiveX control.
That will let you data log numeric or string tag data to a plain text file.
I second using the Datastore ActiveX control. It's a shame that on such an expensive interface, logging is so difficult and antiquated, but Datastore makes it a little bit better. There are some funky things you have to do with macros, but this guide makes it as simple as possible: http://theautomationblog.com/datastore-plus-step-by-step-setup-in-factorytalk-viewstudio/
If you want to log tags in different groups or at different rates, all you need to do is place another activex control on the same screen and configure it accordingly.
Greetings! I am using a PvP 7 4" screen which is sized at 480X272 pixels. The numeric keypad (and especially the alphanumeric keypad) are pretty...
1,785
Hi All I have a PV HMI which is "standard" only, not performance, as was specified. My copy of the FTV editor has a Factorytalklinx facility for...
1,462
I have a PanelView hmi stuck at the boot screen. How can I make it run again? Allen-Bradley 2711-T10C15L1 PanelView 10.1" Touch Screen Terminal
2,481
I am learning how to use the View Designer software. I have worked with FactoryTalk View ME and SE but this is quite a bit different. I have...
2,694
Good Afternoon , I have 3 old Panelview Terminals that I need to replaced. Could you tell me the replacement for the Panelview Terminal 600...
1,887
