Rockwell PLC -- How to know when MobileView is connected?
mikek
Feb 2009
Ohio
I'm using the new display panel from Rockwell - a MobileView Operator Terminal and CompactLogix PLCs / RSLogix5000. It is possible to quickly detach the MobileView HMI and move it from machine to machine. I have a unique FactoryTalk View project for the MobileView and another for a PanelView that sits in front of each machine. MobileView communicates via EtherNet.
Would like to develop trigger some logic to know when the MobileView is connected. In that case I will adjust visibility on the MobileView.
Does anyone know ladder logic I can write that would tell me if the device is connected? I guess I need to somehow interrogate the IP address, maybe send a MSG command to the device and look for an expected response?
Thanks!
// Mike
There is a quick and easy method I have used in the past to confirm PV+ comms. I have a macro set a value of 1 to a bit in the PLC, say PV_HeartBeat. Have an unlatch bit just unlatch it every scan and use that to run a timer with a preset of 1500 mSec. If the timer DN bit ever goes high, I know I have lost comms. Hope that helps.
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
91
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
409
Hi all. This is a very specific issue. My first time with a Modbus ProSoft. Customer setup doesn't make any sense but we're stuck with it...
396
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
813
Hello Gents, I'm now tasked with implementing source control in our projects and although I have more challenges to deal with, a big one to...
1,242
