Rockwell Preferred Modbus Master
lostcontrol
May 2009
NeverSayNever
1,071
We are looking at an application with 10x VSD's, that have Modbus RTU by default. We can also easily add an E/IP card to the VSD.
At this stage we are angling towards a ML1400 & Modbus Serial, but I was just reading a thread abuot the L23E. What would be the option that others would look at for this type of application? The ML & Serial option is far cheaper, but E/IP is so much easier to configure, maintain & support going forward.
I'm assuming the L23E can have E/IP devices as IO etc?
You will not have the best update times with Modbus. My rule of thumb is to have max 8 slaves on a Modbus RTU network at 19600Bits/s using a few coomand/slave. So, if you have any concerns about update times, I suggest to go with EtherNet/IP.
Just my 2 cents
Patrick L
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
69
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
34
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
128
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
194
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
135
