Rockwell PSA 1747-SDN Series C, FRN 8.002
I was concerned when I read that one too, as I specify and recommend SLC DeviceNet scanners by the truckload.
But I've never written a program that wrote Explicit Messages prior to copying Output data to the M0 table. I usually run a bootup timer and check the Device Failure Table before I send explicit messages. Meanwhile, the logic that copies data to the M0 file has run hundreds of times.
I can see where you might have periodic or on-change COP instructions to the M0 file and this could come into play. Bugs that cause outputs to not be set to the correct state are always considered high-priority service alerts.
It's a good upgrade but not a cause for panic.
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
172
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
129
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
114
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
