Rockwell Sample code - xml?
rQx
Oct 2010
Trelleborg
1,051
Hi!
I don't know if it's just because it's Sunday but I downloaded Connected Components Workbench just to try it out. I want to download Sample Codes from RA to start learning the software. But everything I donwload is in .xml and I can't seem to open them?
/Tim
Found it! Turns out that it isn't a program you get but a function block, so you have to import the function block.
I have tried opening several micro800 sample code files with CCW8.0. The file extension is xml on the samples and will not open with CCW. I...
1,643
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
105
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
178
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
130
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
131
