Rockwell Thin Client - Unable to Connect
phuz
Jun 2008
Mohnton, PA
1,044
I admittedly have never set up a Rockwell Thin Client / ThinManager but I need to step in because a vendor is having trouble making the connection and we're not sure if it's on the server end or if there is IT/network issues.
Network connections are good and can ping the server, but upon boot of the thin client, I'm getting "Can Not Locate ThinManager Server (XX.XX.XX.XX)" and there's a lot of finger-pointing going on. On the server end, remote connections are enable, but only with NLA. ThinManager is running.
While the vendor is not currently on site, what additional things can I be looking for?
Thanks.
Is the IP address correct? In my experience, if the IP address of the Thin Manager is correct, it's minutes to get it up and running assuming you have to configure it in the Server. Seconds otherwise.
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
172
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
129
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
114
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
