Routing problems in S7 project
aikona
Oct 2003
B2220 plaas dorpie
182
Hi
Got problem with routing in an S7 project
project consists of varoius PLC's connected via ethernet and or profibus.The lay-out is such that I can connect to all PLC's via ethernet ( direct ) or routed via profibus.Due to a change in topology ( don't you like those smart words) I had to disconnect one PLC from one profibus segment and connect to another segment and ..... I cannot connect to any profibus anymore via routing.One the PLC that does the routing I can still use diagnostics and see the nodes on the profibus segment
Does anybody know where to find the file responsible for routing in a Siemens project and if it can be deleted or 'rebuild'
Tnx
Eric
Hi Jesper
In the project I downloaded two PLC's .The one that got changed on the profibus side and the 'master'PLC ( the one doing the routing).
Would you say that I need to download 'something' to all the other PLC's connected to both 'changed'profibus segments
What needs to be downloaded : the complete station or just the connections and gateways ?
Greetings
Eric
I think that it should be enough to download to the target PLC and the routing PLC, as you have done already.
Is the programming PC a "PC Station" ? If so, I would update that as well.
Hi
I deleted 'PG/PC' object and re-inserted it ,connected an interface and ... when I assign PG/PC I can connect to my lost PLC's but if I now copy the project onto another PG/PC it doesn't connect unless I change the interface properties.
I am relatively certain that the "PG/PC" or "PC Station" must match the target PC exactly in order for the routing to work. So if you have several PG/PC's or PC Stations, you should set them all up in NetPro.
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
191
Kindly, if we enable the routing on the Rockwell Stratix 5700 switch, as in the below link, will it cause any trouble? Like for axis motion...
189
Hi All, Have a question about setting up routing across VLANS. I have attached a picture of the layout and will try describe best I can...
726
Hello everyone, I have a question... is it possible that two IPS in different network segments can see each other through communication between...
1,138
Kepware rookie... For some OEE purposes, we are trying to collect data from a ControlLogix PLC. We have to go thru an another ControlLogix...
1,004
