RS 232 serial interface DB 25 to USB Converter cable for plc.
kiranchand
Aug 2007
United Arab Emirates
Hai All,
I have a PLC(MItsubhishi Melsec FX 48 MR) With me, which is having Serial interface DB 25 port on it. If I use DB 25 to usb converter cable is it possible to make a communication between plc and pc. I have the mitsubhishi plc software with me .
Waiting for Reply.
Regrads
Kiran chand .
I have no clue about Mits PLC's, but I used a IOGear USB to Serial converter on my cable that attaches to the SLC 500 9 pin D sub port.
If you have a DB25 cable, you are going to need a DB9 to DB25 also. I have not seen a USB to Serial converter cable with a DB25 end. All the ones I have seen are DB9 out.
This is the one I have http://www.iogear.com/product/GUC232A/
No... its a RS422 port on the PLC, there are also more part numbers needed to be sure, but if you have a SC-09 cable then you should be good to go, there are also USB-SC09's
If you want to use a USB to serial adapter then look at Keyspan... they are good and have very good troubleshooting software that will help you in the future
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
996
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,557
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,046
So I have a very old radio modem that uses hardware flow control. Its RS232 with RTS, CTS and RTD. I have pins: 2- Tx 3- Rx 5- GND 6- RTD 7- RTS...
1,536
Until recently, I haven't had to connect to a piece of hardware using a serial connection in quite sometime. Well, that all changed yesterday when...
33
6,299
