RS-422 encoder signals: "splitter" or "parallel" ?
Ken Roach
Apr 2002
Seattle, WA
17,481
I have an application I'm considering where I need a device that's generating a master encoder output signal to drive two slave devices at the same time.
The master device is an A-B 2198-ABQE module. Its default output is a 5V RS-422 style encoder signal, so Channel A and Channel B are both differential twisted pairs.
Slave Device 1 is a JVL MAC402 integrated servo motor. When configured for "gearing" mode, it accepts a quadrature encoder input signal with Channel A and Channel B both being RS-422 differential pairs.
Slave Device 2 is an Olympus Focus PX ultrasound analysis instrument. To perform its feature of non-destructive "scanning" of composite workpieces, it usually gets a position input from an actual standalone SICK encoder that has an ordinary RS-422 differential signal output. I want to instead connect it to the same signal from the 2198-ABQE, in parallel with the JVL motor.
I've done applications where I "split" an encoder signal, but those were simpler single-ended HTL type encoders. And the boards were always fragile and got more attention during troubleshooting than I think they deserved.
Are RS-422 encoder signals appropriate for connection in parallel this way ? Can you really do "multi drop" encoder connections ?
The distances would only be a few feet of cable.
Thanks for that perspective and comments !
Again, this is a one-driver, two-receiver system.
There's no risk of multiple drivers transmitting at the same time, and RS-422 is supposed to support ten receivers.
I suppose when you're dealing with multiple vendors, you have to either test thoroughly or plan for isolator/repeater devices.
Every time a customer tried to get away from the (nominal) cost of a splitter and run in parallel, it failed. So they end up having to add the splitter. Waste of time, you'd think they would learn from their mistakes.
Hi, Im a bit unsure about how to connect my SIEMENS encoder (5V TTL/RS422) To my baseunit (The light one).. I have attached a pic of how i have...
1,534
I allready worked with incremental encoders. 24V encoders with an A and a B signal. I allways used the 313C CPU todo such things in stand alone...
9,571
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,049
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,930
This is a little OT but I'm looking for anyone with experience with the Yaskawa Sigma 5 servo drives. We've had some servo drive and motor...
3,541
