RS-485 communication SEW MoviTracB
nightline
Feb 2010
Prinsenbeek
425
Gents,
I've to configure some SEW MoviTracB VFD's.
I can do this on the front panel, or with MotionStudio.
The MoviTracB has a RS485 connection, and I've a Array A-1521 USB to serial converter.
Has anyone experience in configuring a SEW MoviTracB with this Array A-1521 converter and MotionStudio?
How do I need to wire the Array A-1521 to the VFD?
Is it possible to up -and download the VFD configuration this way?
Thanks in advance!
Jack
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
153
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
212
Good evening guys, Please, I need help. This is my first time working with RS485 comm and I dont know what to do. Please, see attached files. I...
425
I am having PLC S7 200 smart model- ST 30 . In which I am getting problem in modbus communication of PLC and VFD via built in RS 485 port of PLC...
773
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
903
