RS 5000 Discriptor copy
robcontec
Feb 2007
Bloomfield Hills, Michigan
25
I was wondering if anyone can help
I have a Controller scoped tag that is used to communicate with the plant floor monitoring system
The Controller scoped tag is made up of Tags aliased from each station
the station tag is maded up of a UDT that contains 3 ints and one dint.
In the controller scoped tag, each member of the int or dint has a discriptor.
The are generic.
I have put in a new line and I need to populate the descriptors in the Controller scoped tag.
The only way I have found to do this is copy the individual descriptor from an existing program and paste it into the descriptor area of the individual member.
The UDT does not allow for descriptors, exporting the tag, does not allow for the expansion of the ints and dints to edit the descriptor. Exporting as an LK5 is the same situ.
I need to populate these descriptors for an extractor program to pull for the Plant floor monitoring system, any suggestions?
I am connecting to a remote device. When attempting to upload I receive an error that states: Error: Auto_Functions: The Import was aborted due...
109
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
89
Hello all, I am currently facing a problem with a Pro-Face HMI PS5000 project file download. I have tried using GP-ProEX SP1 (4.09.350) and...
47
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
501
