rs logix 500 and rs logix 5000
vikas1947
Jun 2011
india
172
what are the basic difference in rs logix 500 and rs logix 5000 ..?..i can make program in rs loigix 500 ..but can i make the programe in rs logix 5000 ..is it so difficult(y)
thanks
In RSLogix 5000 you work with Tags instead of bit and word addresses.
And there are 2 basic types of Tags, controller Tags and Program Tags.
The controller Tags can be used all over your program, but the name can only used once. Program Tags can only used within the program where it is created, but you can use the name more times. So you can Copy a program with only program tags as much as needed.
And of course they're designed for use with different controllers.
RSLogix500 is for Micrologix & SLC processors.
RSLogix5000 is for CompactLogix, ControlLogix, Guardlogix and a bunch of other bits and pieces.
thanks
like rs view 32 scada ...can we use masking in this...
239
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
93
100
190
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
89
