RS Logix 500 password message
Ned_Flanders
Oct 2008
In hiding, England
535
Allen Bradley is not my thing but we have one slc machine and the "Lite" software to get us out of trouble (Or so I thought).
I want to alter a timer value but when I click "Go online" the software tells me there are no matching files. I select the backup (Sent to me by the manufacturer and NOT password protected)but what happens is that the program uploads, it tells me it is password protected from user access.
What am I doing wrong?
Get the exact fault message. There are several different messages
In the window where the ladder should be it says "This program has been protected for user access"
When I hit "Go online" it "finds no matching files"
I selected my files to merge but I get the same message.
If I open "Controller" it will let me put a new password and master password in, and does not have a box to enter the current password.
Either I am doing something wrong or somebody has protected the program!
if you get with your local distributor, you can get the program unlocked. you will have to go through some red tape,
but since you have the program from the vendor, there shouldn't be any problems.
regards,
james
Hi, Contractual issues on both sides are solved if there is any way to have a Read Only password for a Logix 500 PLC program for a MicroLogix...
2,297
Can a SLC500 rack have multiple processor? I read the master password section of the help file and it said: "The idea is that all the processors...
3,690
Is this possible? I have done it with RS Logix 5000 but cannot seem to find a way with 500.
7,309
Hello Everyone, There are two presses at the stamping plant I am located at that are in need of some minor program changes. (Both have AB SLC...
6,222
hi all, i am tring to open an rslogix 500 project from a few years back but the original engineer is now gone and he had a password on the...
6,952
