RS logix 500 still in grace mode
adienib
Mar 2021
Gloucestershire
Relicensed Factory Talk with Rockwell after hard drive failure but RS logix does not see this. It still gives warning that my grace period is about to expire......20 hours left. Any help greatly appreciated Thanks Adrian
welcome to the forum.
since you had a hard drive failure, reinstall the software and go through the relicense procedure. it's been a long time and i can be wrong, i think there is a rehost option for such an event. contact your local rep and talk to the software guru. if you have a tech connect contract, they can issue you a new license. you can go onsite and generate a new license, i would get their help, much faster. i have had t do that in the past on several pc's. ps, you cannot back date the pc.
james
Been a long time since using AB. Looking to emulate a Micrologix 1400 job before the hardware is available. Is there still an emulator available...
1,969
I haven't done any AB SLC programming in years, since at least '02 or '03 and even then I was using older RS Logix software v2.10.12 from I think...
2,473
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
445
268
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
108
