RS Logix 5000 Instruction to search for a tag based on its name??
wine_sparky
May 2016
B.C.
17
I have a RS Logix 5000 program that i feel was poorly structured and I'm trying to make the best of it.
There is a series of approx 40 tags with very similar names (MV_100, MV_101, MV_102, ect....), and with the exact same User Defined structure . The original programmer did not use an array for these tags. Each of the "MV" tags has a member called ".ID" that contains a decimal number that corresponds to the "MV" number (MV_101.ID = "101")
Now, I'd like to refer to these "MV" tags in my HMI without repeating the exact same screen over and over (I don't want to have to create a separate screen to control each individual "MV")
I'm trying to figure out a way to write back and forth, from a temp tag, to the "MV" tag for the purpose of writing to a "re-usable" HMI screen. I can't figure out how to write the HMI values back in to the PLC "MV" values because I can't figure out how to address the "MV" Tag with re-usable code.
I was thinking the answer might be to search for the tag based on the ".ID" value of it, but since the Tag name is different for each I was wondering if there was an instruction to reference a tag based on the string value of its name.
Any Ideas?
I'm not aware of such an instruction offhand.
If you don't mind having to re-load the screen each time you change which tag you are writing to, you could set the tag name as a parameter.
Alternately you could create a set of HMI inputs for each tag, then control their visibility.
This does indeed seem 'poorly structured' as you put it; seems an obvious place to use an array tag. Any reason you can't convert them to an array tag?
On a second reading, I've gotten ahead of myself.
You specify 'RS Logix 5000' but what HMI do you have?
In studio 5000, is there a way to write a force mask into a rung? Long story short, I would like to create a test routine for a FAT test. In...
1,279
Hey guys, thanks for taking the time to look into my question. I'm building a system to monitor several other systems for faults and one of the...
17
4,638
I"m trying to average an array of DINT's called FIFO_ARRAY. It has 1000 elements in it. Here is what I have entered into the AVE instruction...
4,729
Good morning everyone. I am apparently confused on the COP instruction. What I am trying to do is copy a DINT to a DINT in a User Defined Data...
6,954
Hello Please Help, I want to use a FSC instruction that will scan 20 DINT arrays. If the arrays are greater than 1000 display the value. How do I...
1,765
