RS Logix 5000 Interupt
pauly
May 2002
South Wales,U.k
244
If I want to create an interupt in Logix 5000 (V19) so that at on seeing an input I get the corresponding output no matter where the scan is at the time, what is the best way of doing this? Would it need to go into a periodic block?
Any ieas are welcome
I am guessing that it will go into an "event task", with a low number for priority...
I only post this so I can only learn what others say on this matter :)
RSLogix5000 is only part of the puzzle ...
(1) are you using CONTROL-Logix or COMPACT-Logix? ... it makes a difference ...
(2) are you using a LOCAL input or a REMOTE input? ... that can make a difference too ...
Yep it the Event task with "Module Input Data State Change"
See the Task documentation in your logix install
Default location is
C:\Program Files\Rockwell Software\RSLogix 5000\Common\ENU\Docs\Common
you can also look for the Latest version online
aw beat me with a better reply
pauly, why do you need such a fast response - input to output.
just curious as to whether this should be done outside the controller
@ the OP
Not out quite yet but rockwell has some IO modules coming out for contrologix that can turn on a output based on a input in a dedicated time that is dependant on scan time.
IIRC these are due out in Q2 2012.
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
502
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
81
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
166
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
190
