kardel.sharpeye
Hi Guys,
I had a problem with PIDE function block in RS Logix 5000.
Please see the PIDE block attached.
I tried to control temperature control valve to maintain oil temperature @ 170F.
The problem was when the PV is greater than 170, the Cv output is moving slowly to certain point (around 5%) and then suddenly goes to 0, even though the PV is still above the set point.
I've tried to tune the P,I and D gain. but it didn't help.
When i set the P gain at 10, I gain at 5 and D gain at 5. The PIDE seems work allright but then suddenly it stop working because the Cv output stuck at certain value and didn't change even when the PV has changed.
Could anyone tell me how to solve this problem? Is there any mistake that i made in the PIDE?
Thanks in advance
Thanks in advance
