RS Logix 5000 PIDE
bfranklin
Sep 2012
Alberta
125
Hey,
-How do I configure a PIDE function block for feed forward control?
-How do I configure a PIDE function block for cascade control?
Thanks for your help!
How to Turn off the PIDE ???
I have four zones that are now actually able to be tuned using the autotune. My issue is not that.
I have PIDE's that maintain their CVUE values after being disabled. These CVUE's are going into my Split Range Proportional Block that is stuck at 100 even with the PIDE not enabled. I have tried to change the setpoint to 0 wait a little while and then disable the PIDE block but its hit and miss sometimes its off sometimes its at 9.344
I have also tried to force my outputs off but the output keep on flashing. How can shut off the PIDE's and ensure I have zero output on my CVUE's
Ronny,
From PIDE manual:
Function Block: Enable input. If cleared, the instruction does not execute and outputs are not updated.
You can use a SELECT instruction at PIDE output, when PIDE is enable SEL output is CVEU , when PIDE is diasble SEL output is zero.
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
147
Hello im using PIDE in rslogix 5000 - mode is DEPENDENT. im using it to control the temperature, via burners. im having some problems with...
5,131
While troubleshooting control issues due to windup, it would be helpful to be able to view the error term due specifically to the error term in...
1,900
Hi all, Having some issues setting up a PIDE Cascade control loop. Have been trying to go through the Wp008 doc but there's probably something...
5,705
Good Morning , I opened a RS Logix 5000 Oven Program and took notice of about 11 PIDE Function Blocks that are grayed out , and I cannot...
5,610
