rs-logix 5000
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am trying to set up a UDT for scaling an analog input, I have most of it figured out accept for how do I get my input data into the tag to scale it? Is it seen as an input parameter in the UDT set up?
If the input parameter is visible in ladder, you can just fill it in. If it's not, use "mov." If it's visible in function block diagram, tie an input to it. In text use an assignment. Of course, if you were using fbd or st you could just use the instruction "scl" which is already in the software...
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
528
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
93
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
174
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
196
