RS Logix 5000
kirandash
Oct 2014
Hyderabad
Hi there,
I am new to rslogix 5000....and i went to simulate it...but rslogix 5000 is not showing "RS Logix Emulate 5000 Controller" option when I create a new project.
It's not even showing controllogix controllers. The only thing present is compact logix controllers...
Any help????how to get emulator controllers plus controllogix options there..
You most likely have the "Mini" Edition of RSLogix 5000, which supports only the CompactLogix family of controllers.
It does not support ControlLogix or SoftLogix or Emulate 5000 controller programs.
The RSEmulate 5000 emulator is not just a mode of operation for RSLogix 5000; it's a separate purchased and licensed software product.
You would have to purchase the RSLogix Emulate 5000 software. Be sure to download the proper firmware version or you will run into issues, $1500 well spent.
Hi & Welcome to the Forum!
RSLogix 5000/ Logix Designer Software Edition Features...
http://www.ab.com/en/epub/catalogs/12762/2181376/2416247/360807/1837528/tab2.html
You would need say, RSLogix 5000 'Standard Edition' minimum just to support RSLogix Emulate 5000. Then you would need to purchase RSLogix Emulate 5000 separately. RSLogix 5000 Standard Edition will also give you support for the ControlLogix controllers, which your current Edition does not support.
Regards,
George
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
323
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
64
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
135
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
175
