Rs logix
bfranklin
Sep 2012
Alberta
125
In RS LOGIX 5, 500 and 5000 I have the same issue. I am online and I can't force a bit. I right click the contact an the force option isn't available.
I have to goto the data table to manipulate bits.
Any ideas?
THANKS
You cannot force bits in RSLogix 500 or 5000, you can only Force Real Inputs or Real Outputs (or aliases of real ins/outs in 5000).
The only bit manipulation you have is Toggle On/Off, which works, but the logic from the running processor may override it and turn a bit back on or off.
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
73
Hello everyone, has anyone managed to communicate Twido with Controllogix using the Ethernet connection?
40
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
148
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
539
