RS Trend in Logix 5000
TheWaterboy
May 2006
-27.9679796,153.419016
1,940
I setup a trend in Logix 5000 with 2 tags each with a different range
I select the Y axis and select Preset since I want each to have its own range
When I click apply the radio button goes back to Automatic
It does this every time and i can't get it to stay put.
Is this a bug or am I doing something dumb again?
Hi, do you know how i can add pens in a trend by drag and drop the variables, without using "Add/configuring tags" windows. The Add/configuring...
1,155
Hi Folks, I am trying to trend in Logix Designer an element of an INT[223] input data array. For some reason, the "add" button is greyed out. I...
2,227
Hello PLCS.net! Here again to ask about how to do some weird quirky thing with RSLogix 5000. I see my team trending a lot of tags, but it becomes...
1,565
Good Morning , A machine manufacture sent me a trend file (.l5x ) to import in a RS Logix 5000 program they developed. Can you import Trend...
1,308
I am working on a dual spindle winder controlled with a 1756-L71 PLC communicating to four Parker/SSD AC890 drives over Ethernet/IP. The drive...
1,777
