kamenges
I am working on a dual spindle winder controlled with a 1756-L71 PLC communicating to four Parker/SSD AC890 drives over Ethernet/IP. The drive speed generation and the tension loops are located in the plc. While running we get occurrences where we will see significant tension deviations, both high and low.
I set up a trend looking at spindle speed command and tension feedback on both rewind spindles. Here is the odd part. In every case that I have been trending these items, the trend had stopped updating at the same time that the tension issue occurs. Actually, the trend must stop updating slightly before the on-machine event since I never see the tension deviations in the trend. It isn't a long duration issue but at 1500 FPM it doesn't take long to push through enough material to cause some serious heartache.
It just seems too coincidental that EVERY time this happens the trend freezes. I have disconnected my laptop from the plc and the issue still occurs so I know it is not strictly related to the trend function or the laptop connection.
Has anyone ever seen anything like this before?
Keith
Keith
