RS232/DB9 Tricks and Tips Please
Mar 2015
milan, mi
34
I have so many different machines here at my plant that have different RS232/DB9 cables ( straight thru, null, crossover, special cable ) that I have to make/remake and or buy. I was curious if maybe there is something out there that I can buy that will automatically ( or flip a switch)
Mostly its allen Bradley, servo drives and hmi... but I also have seimens too and omoron , emerson, proface, Yamaha, yaskawa, fanuc, Mitsubishi, ormec.....
Just seeing if someone knows something easier....thank you.
I have a little breakout board that is mounted in a little plastic case. It has a DB25 male on one side, and a DB25 female on the other. Then there are 2 rows of female headers that are all numbered, and a little slot in the side of the case to store jumper wires. You can then just use standard jumper wires to wire any input pin to any output pin. A guy could easily build one for DB9 cables.
This is one of the reasons I'm a big fan of Ethernet enabled devices.
Any time I'm working with a new serial device for the first time, I lose at least half a day trying to connect to it. Usually a full day, if I do something so stupid as use a cable someone gives me that they swear they've already tested and it works fine.
The truth, the whole truth and noting but...
...character frame....stop bits....parity....speed....dtr...dsr...cts...xoff...dle...etx...bcc...
...NAK :eek:
30 years with serial connections is why I have so little hair left, and such a long nose.
Kalle
I used to have a set of RJ45 to DB9 & DB25 connectors with each connector having its pins swapped about to configure it for that particular connection.
Now I have an Beckman "Easy BOB" Breakout Box.
Which model of easy bob do you have?
It's a Model 775. It had been sitting on the shelf at Randolph Williams for as long as anyone could remember. So I offered Mike $20 for it, and now it's mine. Heck of a deal. :)
Sorry about the delay, I kept forgetting to go into the garage and look it up. :oops:
Oldtimers... :)
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,577
Hi; In one of our flexo printing machine, the communication protocol between HMI to 48nos frequency inverter drives for setting motors is RS485...
4,830
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
106
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
253
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
745
