RS422 and 5 euro wires
krome
Jan 2009
michigan
31
I have a 5 wire euro that need to be connected to an rs485 but I don’t have one I was wondering if I can use a rs422 if so how will I connect the 3 wires to the rs422. I have an external power supply for the equipment already(12VDC) the 5 euro wire are as follow
1) +10 thrue 30V dc input
2) rs485/d1/B/+
3)dc common (GND)
4) rs485/do/A/-
5) comms gnd
The rs422 has 5 connection where the three wire can go, which are as follow
Tx+
Tx-
Gnd
Rcv+
Rcv-
How can I connect it if I can work and would I need a special drive beside the one I usually use for the rs422
Thanks for your help!!!
Impossible to know if it will work.
RS-485 is by definition a tristatable communications buff, based on differential signals. That is why on RS-485, you can use 2 or 4 wire.. 2 wire becomes half-duplex, and works by tieing the Tx+ to RX+, and the TX- to RX-. For 2 wire RS-485, you must have a bus devices that understand the need to switch between floating the TX outputs or not.
RS-422 is based on nearly the same differential signal levels, but in general has no provision for being tristatable, and always operates in a full duplex mode (between master and slave(s) ).
Many interfaces are indeed convertable, as the signal levels are similar, but ONLY if they can properly handle tri-stating.
The best answer for you would be to contact the equipment manufacturers.
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,044
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,923
This is a little OT but I'm looking for anyone with experience with the Yaskawa Sigma 5 servo drives. We've had some servo drive and motor...
3,537
Hi, Im a bit unsure about how to connect my SIEMENS encoder (5V TTL/RS422) To my baseunit (The light one).. I have attached a pic of how i have...
1,531
I'm using a Micrologix 1100 and I want to add a sensor that has a RS422/ASCII output. The sensor outputs a series of messages in hex format over...
1,471
