Rs485 Communication With Micrologix Ab
pcontrol
Dec 2002
WE WANT TO GIVE COST EFFECTIVE RS485 COMMUNICATION WITH MICROLOGIX.
PROBLEM IS THAT WE ALSO HAVE TO GIVE MMI. DUE TO MMI ONE PORT IS USED
IN PLC FOR REMOTE COMMUNICATION.
IF MMI HAVE TWO PORTS, ONE FOR PLC THE OTHER FOR RS232C/RS485 THEN
WILL IT BE ECONOMICAL?
WHICH MICROLOGIX WILL SUPPORT MODBUS / RTU PROTOCOLS?
IS IT POSSIBLE PLC GIVES DIRECT RS485 COMM?
IF NO WHAT IS THE PRICE RANGE OF RS232C/RS485 CONVERTERS?
AB have 232 to DH485 interface for about AUS$277.
AB part number 1761-NET-AIC
Not quite sure what you are trying to do, do you want use a micrologix with a microview, panelview?
If your panelview has a RS232 DH485 you should be able talk to both the panelview and the PLC through this port depending on what type of plc you are using.
If any one can share a sample program for communicate micrologix plc with powerflex drive for start/stop and frequency write.. It will be greatful...
2,153
Hi.. I am using Micrologix 1400 PLC & C600 HMI. I want to do the communication between them by DH-485 via RS485 port.( As distance between them...
4,298
Good evening guys, Please, I need help. This is my first time working with RS485 comm and I dont know what to do. Please, see attached files. I...
416
Hello I have 1 loadcell, 1 loadcell transmitter(rs485(RX, TX) communication) a s7-1200 plc and a cb1241 rs485 module. Now i need to write a code...
55
36,510
Hello Everyone, I am looking for communication with delta PLC and barcode scanner over RS485 Please help.. The ladder program will be helpful...
1,877
