Hello all, I have a small programming issue for you. I have 6 250hp water pumps with 2 of them on VFD's. Engineers are wanting to automate these pumps. What they want to do is run the 2 pumps on VFD's all the time with a setpoint based on header pressure. If the VFD's cannot handle the load then start one of the other pumps, and after a certain time if the pressure does not come up then start another pump and so on. I have the programming done for one and I am testing. My issue is that I need to be able to rotate the starting of these pumps so that we are not accumulating excessive hours on one pump. Any one ever done this before? Do you have any sample code I could work with? Thanks,
