Rslink, excel and mysql database
Added MariaDB/MySQL logging to my generic command-line pylogix logger, cf. here.
Two lines compose the guts of what was needed;
### Connect to database and instantiate a cursor in sub-class .__init__(...) method:
self.cursor = MySQLdb.connect(autocommit=True,**mysql_kwargs).cursor()
### Write data to a new record (row) in .__class__(...) method:
self.cursor.executemany("""INSERT INTO log (tag_name,tag_value,timestamp) VALUES (%s,%s,%s)""",self.changeds)
The rest is one-time setup stuff and window dressing to handle the command-line options.
Newcomers to MariaDB/MySQL will spend more time learning the DB ecosystem than writing code.
And this is one way to extract those data from MariaDB/MySQL:
$ mysql test_drbitboy -e "select * from log where tag_name<>'seconds' or mod(tag_value,10)<1" -vvvvvv
| rowid | timestamp | tag_name | tag_value |
| 52 | 2022-01-31 19:30:33 | minutes | 31 |
| 53 | 2022-01-31 19:30:33 | hours | 14 |
| 54 | 2022-01-31 19:30:33 | day | 31 |
| 55 | 2022-01-31 19:30:33 | month | 1 |
| 56 | 2022-01-31 19:30:33 | year | 2022 |
| 59 | 2022-01-31 19:30:36 | seconds | 20 |
| 69 | 2022-01-31 19:30:46 | seconds | 30 |
| 79 | 2022-01-31 19:31:04 | minutes | 31 |
| 80 | 2022-01-31 19:31:04 | hours | 14 |
| 81 | 2022-01-31 19:31:04 | day | 31 |
| 82 | 2022-01-31 19:31:04 | month | 1 |
| 83 | 2022-01-31 19:31:04 | year | 2022 |
| 85 | 2022-01-31 19:31:06 | seconds | 50 |
| 95 | 2022-01-31 19:31:16 | seconds | 0 |
| 96 | 2022-01-31 19:31:16 | minutes | 32 |
| 106 | 2022-01-31 19:31:26 | seconds | 10 |
| 116 | 2022-01-31 19:31:36 | seconds | 20 |
| 126 | 2022-01-31 19:31:46 | seconds | 30 |
| 136 | 2022-01-31 19:31:56 | seconds | 40 |
| 146 | 2022-01-31 19:32:06 | seconds | 50 |
| 156 | 2022-01-31 19:32:16 | seconds | 0 |
| 157 | 2022-01-31 19:32:16 | minutes | 33 |
| 167 | 2022-01-31 19:32:26 | seconds | 10 |
23 rows in set (0.026 sec)
Bye
Hello friends; I found a code for VBA use in excel to read the Tags values from RSlogix 5000 through RSlink. The code is here: Dim OPCServer1 As...
3,891
Good afternoon, I have a problem communicating with a system, I will explain it briefly. I have a HIS -ML17- CTBH monitor connected to an...
16
447
Hello Friends; Good day. I have RSLINK 2.52 i have also 1784-U2DHP. But in the RSLINK configuring driver there is no 1784 U2DHP shown in the...
2,136
Hi all, Kindly find the attached snapshop.I got this error while try to connect RSLogix 500 to wonderware intouch.
1,146
Dear All: open the rslink classic launch control panel ,you need " stop"and then cancel the "always run as service "and then "start". if it can...
1,295
